Just an FYI about 8 spd transmissions
Dick&Cheryl
What are your RPMs in L7? Driving at 70 gets me 2200rpm. Go into manual, it puts me in L6 and RPMs go up. L7, RPMs go to 2200. L8 shows on screen but no RPM change. Means it’s not actually upshifting to L8, it’s staying in L7
Yep. That's the way ours works, even on warm days.
GaryM
That's correct. 8th gear, for some reason, has some pretty strict performance parameters to meet before it will actually shift into 8th gear. But be sure, if you're at 70 mph and the engine RPM are 2200, the transmission is in 7th gear regardless of what the paddle shift on the dash says, even though it says L8. Even with ERS (paddle shift), if the performance criteria is not met, you can't force it. After a lot of testing I figured out that 8th can be achieved with 0% throttle using the paddle shift at 70 mph, on a slight downhill. It will default to 6th, then upshift through 7th then 8th gear slowly. If entering a highway posted for 70 mph you can achieve 8th by keeping speed below 62 mph, 0% throttle. It will stay there as you accelerate to 70 mph if done very slowly. Too much throttle and it will downshift to 7th and stay there. I do it all the time and it works. I get 8th gear (1800 RPM) at least 90% of the time. I know, to some, this all sounds a little goofy and I admit it is. It certainly is not the kind of thing anyone who owns a newer vehicle should have to do the get full use of all the gears and the benefits. All of us accelerate to road speed, level off, and either hold the speed or use cruise control and expect the transmission to shift to the highest gear appropriate for the conditions. In this case, if we drive that way, the appropriate gear in GM's design mind is 7th, even though achieving 8th via the above mentioned methods will work just fine. I live around 25 miles from town, yet when I get it into 8th gear it will stay there and perform very well with fuel economy at around 31 mpg. I've had several conversations with the folks at GM about this without getting one solid explanation as to why the TCM is programmed the way it is in regards to the use of 8th gear. They've agreed that my assessment of how it performs once in 8th is accurate but they are not willing to accept they're mistaken in their coding as to how it must be achieved. They just can't seem to accept that "normal" driving habits will not use 8th gear at all using current programming.
TheBeiters
Michigan
I found that if I go to 62mph with cruise on (the old school style, not the adaptive), it will shift into 8th. I can then walk it up using the cruise button 1mph at a time and it will stay in 8th even on most minor hills (I75 south from Mackinaw has some minor hills). Keeps the RPMs sub 2k and I was getting 30mpg. So yeah, it’s not the computer saying it’s the best gear for fuel economy, it obviously will stay in 8th. It’s the entry conditions that are a mess. GM screwed the pooch on this one in my opinion and should rectify it.
GaryM
1000% they should fix this. The question is will they?
That's a good question. It should be fixed and since it's a programming issue I wouldn't think it would be that difficult. I tried reprogramming the TCM thinking it could have been corrupted through not fully completing the original download. That didn't help at all. Right now I've modified my driving to get as much use out of 8th gear. The only time I have to use the ERS is when it's downshifted to 7th. I have to manually get it back into 8th. Certainly not how we normally have to do it. Sure is disappointing that GM has ignored this. It's been around a long time (2 years) with nothing done.
