front seal
wajerry90
Eastern Washington
I have a 2011 Chevy Equinox with the 2.4, 4 cylinder and I bought the car in March and have been working out some of the issues like the cat was full, and brakes, I replaced the front crank seal about 2 months ago and have had no leaks since. But we have been having some really high heat in the area and twist when I am sitting in traffic say at a long stoplight it will blow oil out from behind the seal. It did it just tonight. Can that engine be building up pressure while waiting at an idle because that is when this happens is just at an idle. The engine purrs down the freeway just fine. I could use a few ideas I am one that really likes the car and engine. Thank you.
You have posted your question in the 4th generation forum (2025 & up models).
You may want to post your question in the 2nd generation forum (2010 - 2017 models) as you may get more views and replies?
moved your thread to the right place. Do you have the oil fill cap with the breather? If not, that might help.
