It's a poor approach to vehicle performance, short term and long term. Short term, fuel economy has to be impacted just by the fact the engine is turning more RPM's at road speed. Slowing the engine while maintaining road speed will save fuel, place the engine RPM's in a more favorable position in the torque curve. The amount of fuel it saves is a moving target as there are a host of things that drive MPG besides RPM. Long term, engine life. Lowering the RPM thus reducing the number of revolutions in it's life time reducing wear. There has to be some reason GM has chosen to use this approach in their 8 and 9 spd transmission applications. Owners of vehicles (all GM but not just Chevrolet) say their 9 spd work the same way. It suggests the top gear is an overdrive. I don't have access to the total gearing to determine whether that's a fact or not. Even if it is, having it function in this manner doesn't make much sense. One other point to mention is how it performs in cruise control, especially when adaptive control is turned on. Once in 8th gear, cruise on the vehicle can perform very well. As a slower vehicle is approached the cruise will slow down to their speed. If they speed up quickly or pull off cruise will accelerate to the set speed but the rate will cause it to downshift to 7th. It will never return to 8th gear. To get back, ERS (paddle shift) must be used to get back into 8th. The default for ERS is 6th gear. When it's turned on engine RPM's will go to 3000 at 70 mph. Upshifting with the paddle will get to 7th (2200) then 8th (1800), if there's no acceleration load on the drivetrain. Seems there's too much interaction required to get the benefit of an 8 spd or 9 spd application.
I also have a 2024 Chevrolet Tahoe Premier 4WD with the 10-speed automatic transmission. I have heard others say that it will not often shift into the 10th gear. I cannot tell on my Tahoe if it reaches 10th gear on the expressway.
You’re right that there must be a reason GM is choosing to program their 8, 9, and 10-speed transmission's this way?
