2010 Chevy Equinox LTZ - Engine oil leaking
RedPlus
I found an oil leak on top of my 2010 Chevy Equinox LTZ engine. The photo is attached. Can anybody tell me what it is and how can I fix this?
Thank you in advance!
bradpotter47
The leak appears to be coming from your PCV air intake and is likely the result of a clogged air intake. I recommend you either clean the air intake yourself or have your dealer do this as soon as possible. If not, the clogged air intake will result in excessive pressure build up and a blown rear main oil seal. If you're on the road when this occurs, it could destroy the engine.
