Whining Noise starts around 20mph and gets louder
refderek
2006 Equinox
71,000 miles
Non-AWD
A whining noise appears around 20 miles per hour and gets louder until about 50 mph and stays about the same there at higher speeds.
Had tires checks - all good.
Ran engine in PARK at 2,000; 3,000 and up until 4,000 RPMs with hood open, no apparent noise, so I wanting to rule out pulleys, belt, PS pump and alternator.
Any suggestions on what this may be? Thanks you. Derek
refderek
Got it solved - Hub Bearing Front Passenger Side; these are known to go out on the Equinox.
TheDarkKnightKnox
Columbus, OHIO
Glad they found the issue, its a shame it happened below 100k miles.
My first car a 95 Bonneville didn't need a new bearing hub until 200k miles and that was because the speed sensor was bad and built in.
I had to replace all of the hubs at 130k miles on our Saturn Vue before we sold it. I think they went bad because they hauled a trailer that was way too heavy. If I could guess accurately, 5000-6000lbs....
Sent from my XT1080 using Tapatalk
jne232
Erie, PA
A wheel bearing/hub....
I've replaced one on almost every Chevy I've ever had. All below 100k. The older Blazer/Jimmy's...all the time. Lol!
Member Recommended
