Traction Control Error Clears When Left Front Tire Raised
wksiez
New to the forum, I have a 2006 Equinox 2WD - with code C0035 - Left Front Speed Sensor but when I raise the left front tire slightly the error code disappears. Is this indicative of a hub or a sensor/cable error? No visible breaks or rubbing on the sensor wires/sheathing. Any help thank you in advance.
wksiez
I replaced the driver side hub and sensor and now shows codes C0035, C0245, and C0040 are now showing. I think its the ECBM? thoughts ideas..
