RCDLR?
My 07 equinox has tpms. But, it will not go into the relearn step used to reset each tire location. The DIC says press “check” button on dash to start and it does not proceed. Been told my rcdlr remote control door lock remote module is bad? It’s behind C panel on pass side. Anyone here have any info on this thing?
I been told they almost never ever fail. So, no info online
bearbait
Have a 2008 Nox and my remote will not work for the locks. Will only work with buttons inside. Wonder if I have same problem.
Ordered a scan tool that does tpms and srs.
I’ll see if I get anywhere with tpms issue.
Scan tool would not work on tpms relearn.
So, I got another RCDLR module and tpms and keyless work now.
I see the relearn steps on dash do work now
And I programmed another key fob.
So, all is well
I switched wheels from 07 to 08. The tpms works fine on 07. I tried to reset tpms on 08 today and it said all 4 programmed ok. I shut off car and 1 hr later restarted it and system only sees 2 pressures, not 4. I didn’t drive it. Maybe it is speed related?
