Lock and check all your doors and see if they are all locked after exiting your vehicle. When my driver's side LED wasn't lit my rear door lock wouldn't lock. Usually when either LED is out, one of the door lock actuators are bad. If all your door locks work, then that is not your problem. When I found out which door lock wasn't working. I replace that actuator and that solved my problem.
