2012 Lemon
nijoani
Sacramento, Ca
Hi this is my first post. Got a 2012 Equinox w/95k miles a few years back. It was using oil and I did not think much of that. What I did not know is that chevy built a lemon engine. They compounded the problem by using a tiny oil filter. So at 106k miles the timing chain stretched and the computer would not allow the engine to run. So I have decided to rebuild the engine. We got it out and tore it down and sent the head a block to the machine shop. Google says that aftermarket oil rings will fix the problem. I am sure many of the people on this site have had similar issues with the 2.4 L engine. I am looking for advice on gasket kits, rings. and references for proper ways and tricks for reassembly. And the success any one has had in resurecting these engines and bad experiences for same. Thanks
Nick
59Squire
THE VILLAGES, FLORIDA
Nick
Sorry I can't help. My 2012 has over 205,000 miles on it with no engine or transmission problems.
There's a few 2.4L rebuild threads on the site. For the most part, oil consumption can be avoided by going above and beyond with engine oil changes from new, to keep the PCV orifices and oil control rings free and clear. Today, I believe oils like valvoline's restore & protect or mobil1 advance clean would help significantly.
Sorry to hear about your issues. Your 2012 could have led a hard life prior to you buying it. IMO, 5K mile oil changes is pushing the limits for the 2.4.
John H.
Charleston SC
Nick
Timing chains usually stretch from Oil dilution ( too long between oil changes) or running with the oil low.
moman406
There was a tbs on the Ecotech 2.4 l engine. Gm would replace the pistons and timing chain free of charge if engine was under 120 k miles. I had it done to my 2010 at 106K miles. These engines are prone to oil consunption and timing chain guide breaks. I did oil changes at 4K miles so service was not an issue.
