2012 Equinox 2.4L engine rebuild, looking for insight from experienced engine builders
jfbrubaker1969
South Central Pennsylvania
I have a 2012 Equinox with 170,000 miles on an oil burning 2.4L Ecotec engine. My daughter was not good about checking the oil and the timing chain skipped enough teeth that I have 13 broken rocker arms and 13 corresponding bent valves.
My plan right now is to do a significant overhaul on the engine, keeping the block in the vehicle. Rebuild the head with new valves, new rockers and hydraulic lifters. Replace the pistons and rings (and maybe connecting rod bearings) to hopefully resolve the oil burning problem. I'm considering doing the EGR oil separator mod as well. New timing chain set, new phasors and VVT solenoids, new oil pump. Water pump was replaced about 2-1/2 years ago.
I pulled the head today and removed the cam shafts. Most of the camshaft bearings look fine, but two of the bearings did have a single scratch that I can just barely catch with a fingernail. I did a quick inspection of the cylinders and did not see any sign of damage or scarring, but after 170,000 miles, there's no trace of cross hatching on the cylinder walls.
So my questions for the experienced builders are: How much wear is acceptable for things like the camshaft bearings, connecting rod bearings and cylinder walls? What other things do I need to pay attention to that could cause issues (especially with keeping the block in the vehicle)?
My plan is to post a bunch of pictures showing the current wear of the items I am concerned about.
Thanks for taking the time to read my post and for any helpful pointers.
jfbrubaker1969
Here's the exhaust cam. I took pictures of each group of lobes/journal and then rotated the cam 180 degrees and took another set of pictures.
Cylinder 4 lobes/journal
Cylinder 4 lobes/journal - rotated
Cylinder 3 lobes/journal
Cylinder 3 lobes/journal - rotated
Cylinder 2 lobes/journal
Cylinder 2 lobes/journal - rotated
Cylinder 1 lobes/journal
Cylinder 1 lobes/journal - rotated
jfbrubaker1969
Here's the intake cam. I took pictures of each group of lobes/journal and then rotated the cam 180 degrees and took another set of pictures.
High pressure fuel pump lobes and journal
VVT journal
jfbrubaker1969
After I stripped everything out of the cylinder head, I mixed up Simple Green HD Pro cleaner (which is safe for metals) and hot water in about a 1:5 ratio. With the container I have, it could only cover about 2/3 of the cylinder head, so I soaked the bottom side for about 6 hours and then flipped it over and let the top side soak overnight. I am super impressed with this cleaner and will be using it exclusively to clean engine parts from now on! I pulled the cylinder head out of it's bath and put the cam shafts in for a soak.
I spent about 3 hours with various brass bristle brushes and my pressure washer on some of the spots that required additional cleaning. For those that don't know, brass is softer than aluminum, so it won't scratch the aluminum, this is very important on mating surfaces!!!
I was very surprised at the amount of carbon build up in the intake ports, it was so thick in some spots I had to use a screwdriver to scrape it off! Since the 2.4 is a direct injection engine, I was expecting this, but after researching it online, it appears to be a common issue with the 2.4 Ecotec.
After I finished, I used my air compressor to blow off as much water as possible and let it sit in the sun for a few hours. I made a careful inspection of the valve seats and they all look to be in great shape. With the cylinder head done, I pulled the camshafts out from their bath and cleaned them up with the brass brushes as well. While the cylinder head and cam shafts don't look brand new, they do look pretty damn good!
Before and after:
Here's a shot of the valve seats. My eyes aren't as good as they used to be, so it's helpful to have a high res pic to zoom in for a close inspection.
And finally the camshaft. There are two oil seals on the front of the camshafts that are important for the VVT (Variable Valve Timing). While the seals that are currently on the camshafts look to be in good shape, I figure it would be stupid not to replace them at this point.
I have the valve springs soaking in the cleaner and I'll be soaking the camshaft bearings overnight as soon as I go to the store and pick up some plastic cups so that I can soak them individually to keep them from getting mixed up.
jfbrubaker1969
So over the weekend I finished cleaning the head, concentrating on removing the remaining built up carbon in the intake ports. I lapped all of the valves and got them installed, installed the new hydraulic lifters, rocker arms, cams and the VVT cam sprockets. So at this point the head is ready to reinstall.
Today I dropped the oil pan and removed the pistons. I gave the cylinders a wipe down and with my flashlight at the right angle, I was able to see there is still some cross hatching on the cylinder walls. I'm still going to measure the bore, but I'm feeling pretty good that I won't have to pull the block and get the cylinders bored oversize. I also inspected the connecting rod bearings and journals and didn't see any sign of scoring, that's a big win in my book!
I'll see if I can get some pics posted later tonight.
jfbrubaker1969
Here are the latest pics.
Cam bearings all cleaned up
A close-up pic of the valve seats I took after lapping to make sure they looked good. All the valve seats looked perfect (zero pitting) and good contact area between the seats and the valves.
Valves stem seals, valves, valve springs, keepers and hydraulic lifters installed.
Rocker arms, cams and VVT sprockets installed and torqued to spec.
I soaked the ends of the spark plugs in some cleaner and lightly scrubbed them with a brass bristle brush, they cleaned up really well. I was hoping they would since they are less than 3 years old.
So, you paid “retail” for equinox. And don’t want to buy a new $4000 motor to fix it? I found a 2015 w/98k miles for $1k. Seems to me it’s almost not worth putting in a new motor?
jfbrubaker1969
Not sure how you jumped to the conclusion that I paid 'retail' or that I'm putting a $4,000 engine in it?!? We bought it used about 6 years ago and I'm not putting anywhere close to $4,000 into it. Other than the damage caused by the timing chain failure, the vehicle is in great shape. So if I put in maybe $1,000 into rebuilding the engine, solving the oil consumption issue and have it last another 4-5 years?!? That's a pretty decent investment!
jfbrubaker1969
So I spent last weekend measuring the cylinder bores and gapping the new piston rings. There is some wear on the bores, but they're within specs and some cross hatching is still visible on the cylinder walls, so they do not need to be bored out. I gapped the compression rings and properly sized the oil control rings spacer only to find that the set of Mahle/Clevite rings I bought only had 7 of the 8 required top/bottom oil control rings.🤬
RockAuto was good about sending another set of rings, so I will remove the one oil ring I need and send the rest back. I removed the connecting rods from the old pistons and installed them on the new Silvolite pistons I bought. Between the Mahle rings and the additional oil drainage holes in the new pistons, I'm feeling confident that excess oil consumption won't be a problem any longer.
I also cleaned up the oil pan, there were quite a few broken bits of plastic from the various timing chain guides in the pan and also in the oil pickup tube. When I pulled the pan, it was basically covered in a layer of black sludge and not it looks like new. I have to say again how amazing how amazing Simple Green HD Pro cleaner/degreaser is. I'm still using the same batch I soaked the cylinder head in and even though the water is black as coffee, it still cleans great! So far it's been used to clean the cylinder head, valve cover, valve springs, oil pan, cam shafts, cam shaft bearings and connecting rods.
So my hope this weekend is to finish getting the rings gapped, install the pistons and get the cylinder head installed. Once that is done I will temporarily install the oil pan so that I can block up the engine and get the front cover removed so I can install the new timing chains and guides. I don't want to permanently install the oil pan until after the timing chains are done just in case there are some broken bits of the timing chain guides that fall down into the pan.
I got a LTZ to fix last year. Very cheap but it had a lot of rocker rust. Got rid of it pretty quick.
