Just a FYI, it was the manifold, it had a crack. All fixed and no more smell.I have a 2017 Equniox 145,000 miles, sometimes I have an exhaust smell coming through the vents but eventually goes away.
I did pass the emmissions test recently. Any ideas ?
Thanks in advance!
I don't know, I didn't see it.Look like this?
Did you fix yours? Or have a shop do it? I’m up north in the rust and not sure if I should pay to have somebody do it. 2013 equinox with secondary air so it’s a pain if there’s rust.Look like this?
It was the manifold. Thanks.Cracked exhaust manifold would be my guess. Super common on the Equinox 2.4L of this vintage.
It was the manifold.Did you figure out/fix the problem you were having? Curious what the resolution was
Did you replace it?It was the manifold.
