2016 Equinox Sunroof Drain Issues
This is a discussion on 2016 Equinox Sunroof Drain Issues within the 2010+ Equinox Maintenance forums, part of the Chevy Equinox General Discussion category!
So, after heavy rain I get water from the sunroof dripping down the right-front pillar, and onto the front passenger ...
Old 09-01-2016, 01:57 PM   #1 (permalink)
jneubauer is on a distinguished road
Question 2016 Equinox Sunroof Drain Issues
So, after heavy rain I get water from the sunroof dripping down the right-front pillar, and onto the front passenger seat.
The last time this happened, I got an air compressor, and managed to blow out the line - or maybe it stopped raining hard.
A couple of questions:
1. Where is the exit to the drain located? Is it in the rear wheel well, like older models? Is there a diagram or picture of it?
2. Assuming that I can find the exit point, can I access it, to try to clear it?
3. Is there a "coupling" in the pillar (or elsewhere) that could be disconnected, and is a problem only when it rains hard? If so, where exactly is it located, and how do you access it?
jneubauer is offline   Reply With Quote
Old 09-07-2016, 10:08 AM   #2 (permalink)
For petes sake take the car into the dealer for repair service. The sunroof should not be leaking and if it is the drain should be outside the vehicle not down the pillar and inside. I can only assume the drain pipe has not been connected properly.
coupling, drain, leak, sunroof, water
LED/HID lights in a new 2016 Equinox srjacob99 2010+ Equinox General Forum 1 02-01-2017 06:04 AM
Sunroof Drain Tube disconnected - Need Help rdhunter7 2010+ Equinox Maintenance 1 05-04-2016 02:36 PM
2016 Equinox V6 bcnvz28 2010+ Equinox General Forum 4 09-05-2015 10:01 PM
2016 Equinox jsfb6pts 2010+ Equinox General Forum 8 07-12-2015 04:57 PM
Drain windshield washer fluid Ken Rosey The Official "How To:" Section 4 11-13-2011 03:03 PM
