program a replacement key transponder
This is a discussion on program a replacement key transponder within the The Official "How To:" Section forums, part of the Equinox, Terrain & SRX Knowledge Center category!
I recently purchased an extra 5 button key transponder for my 2011 Nox LT. It is the exact kind GM ...
Old 12-02-2011, 09:24 PM   #1 (permalink)
achtung3945 is on a distinguished road
Default program a replacement key transponder
I recently purchased an extra 5 button key transponder for my 2011 Nox LT. It is the exact kind GM uses (Strattec w/ matching FCC code for my make and model) purchased from amazingkeys.com. I supplied Amazingkeys.com with the key code and they cut the blade for me as well. However, when I took the key to the dealer to program it they were having problems and said it wasn't programming. It's a simple process to program. Just put the old key in and turn to the "on" position until the security light turns off. Then do the same with the New key and then it should be programmed but it wasn't. The cut of the key works fine it's just the chip that is not taking the correct programming.
Any thoughts?
achtung3945 is offline   Reply With Quote
Old 12-03-2011, 07:21 AM   #2 (permalink)
jsfb6pts's Avatar
I would have spent the extra money and bought it from the dealer .
You had to go there anyway for programing.Now you have to send it back .
Old 12-03-2011, 02:35 PM   #3 (permalink)
If they can't program it I would send it back.
Old 12-05-2011, 02:28 PM   #4 (permalink)
Yeah, I hate being held hostage by the dealer but I probably should have gotten one through them in the first place. Bummer for me.
Old 12-05-2011, 04:09 PM   #5 (permalink)
jsfb6pts's Avatar
Check your dealers web site ,most have printable discount coupons
key programming, rke, transponder
Replacement WiperBlades?? 2010BlkGraniteNox 2010+ Equinox Maintenance 55 12-13-2018 01:07 PM
AC Lamps replacement oleg1981 The Official "How To:" Section 5 03-10-2013 11:02 PM
Need confirmation on Bulb replacement.... parlyle Exterior Modifications 3 11-02-2011 08:32 PM
Side Mirror Glass Replacement Feyen1119 Exterior Modifications 8 06-17-2011 11:58 PM
Side view mirror replacement Paniller Exterior Modifications 1 05-16-2011 12:48 PM
