-   The Official "How To:" Section (http://www.chevyequinoxforum.com/f34/)
-   -   High pressure fuel pump (http://www.chevyequinoxforum.com/f34/high-pressure-fuel-pump-1157/)
bhotz 05-23-2014 02:25 PM
I have a 2011 equinox has a 2.4 rough idle at stop lights some hesitation when you take off continues to run after you turn the key off but there is no fuel in the oil.
ThePapaJohn 08-04-2014 12:30 PM
A few things come to mind:
Malfunctioning injector (s)
Incorrect timing (easy check)
Buildup of carbon in the cylinder (pull your spark plugs [one at a time] and a quick peek might reveal)
These are the leading causes these days for gasoline engines to have a "dieseling" problem.
With you having a rough idle and hesitation to boot, sounds like a timing issue. How many miles on it? When were the plugs/wires last changed? (I've lost count on how many times I have come over to someone's house that attempted to DYI a poor man's tuneup - and miss wired - causing this problem....
Update info always appreciated ~ even if you fixed it on your own...
