2014-2015 Headlamp bulb replacement
This is a discussion on 2014-2015 Headlamp bulb replacement within the The Official "How To:" Section forums, part of the Equinox, Terrain & SRX Knowledge Center category!
Can anyone provide a link to a DIY for replacing the headlamp bulbs on a 2014-2015 LTZ. I have searched ...
Old 08-09-2015, 04:39 PM   #1 (permalink)
TEL
TEL is on a distinguished road
Default 2014-2015 Headlamp bulb replacement
Can anyone provide a link to a DIY for replacing the headlamp bulbs on a 2014-2015 LTZ. I have searched around, but cannot find anything thorough or anything will a good series of pictures. I have a 2015 LTZ and I would like to replace the stock lowbeam bulbs with zxe's. I've seen how-to's with the older style access panel in the wheel well, but they do not apply. The headlight assembly is easily accessible and it appears to be secured with 3 hex nuts - all easily removed. At this point the lamp assembly seems to be loose and will pull away from the body slightly except for the lower portion toward the wheel. I cannot find any other retaining fasteners, and there is a video on YouTube of this process on an older model - 2009 I think - and in it it's mentioned that there is a 'ball clip' in that area. The guy in the video just pulls the assembly and it pops out. He uses a good amount of force - i put quite a bit of torque on mine, but nothing would pop free. Any good links to a vids, picture series, or even a tech manual would be greatly appreciated! If some one could confirm that there is a 'ball clip'/ tension clip of some sort and I can simply pull it forcefully with out ripping the front off, that would be great too! I'll make a DIY of the entire process!
Thanks!!!
TEL is offline   Reply With Quote
Old 09-14-2015, 09:33 AM   #2 (permalink)
There is a access hole in inside each of the front fender liners. There is a twist out access panel to be removed to allow you to access the bulbs.
headlamp off delay empots 2010+ Equinox General Forum 3 09-19-2014 02:14 PM
2015 Equinox redesign TheDarkKnightKnox The Lounge 1 03-16-2014 06:34 PM
How To Install Replace Headlight and Bulb Chevy Equinox 05-09 1AAuto.com 1ATony The Official "How To:" Section 1 04-12-2013 07:09 PM
Bulb Change on 2012 LTZ Nox with Projectors PFinnegan Exterior Modifications 2 02-22-2012 03:38 PM
Need confirmation on Bulb replacement.... parlyle Exterior Modifications 3 11-02-2011 08:32 PM
