AMalfunction
- Joined
- May 15, 2015
- Messages
- 3
- Reaction score
- 1
I have a 2006 Equinox with 64,000 miles. It's been regularly maintained and has never overheated.
Recently it started making a faint gurgling noise in the dash on cold start, that goes away when the car warms up. It doesn't overheat, temp stays between 1/4 and 1/2, occasionally hitting 1/2 but no higher. It doesn't smoke, isn't losing coolant that I can see and isn't running rough, it runs fine. There are no visible leaks.
I was doing searches for the noise and came up with head gasket problems so I took it to my regular mechanic, who I implicitly trust. He pressure tested it and found nothing, it didn't leak. He also found the internet posts about head gasket problems but didn't want to charge me for a repair it might not need and told me to drive it until it came up with other symptoms.
I'm a worry wart and I need the car to get my kids to school in a different district. I'm also on a fixed income so if there is a problem I want to get the problem taken care of in its infancy before it gets more expensive. So I took it to the local dealership. They told me that a head gasket issue is really rare in this model and thought it was the radiator cap. They kept it two days, did a complete flush of the cooling system, put on a new cap and said it was holding pressure and the noise was gone and gave me my car back. That was yesterday. According to the receipt, there were no codes in the computer to indicate a problem and there's nothing on this in the GM databank.
Problem is when I started it this morning, it's making that same noise. I called the dealership and they said I could spend a lot of money chasing ghosts but until and unless it actually overheats there isn't anything they can really do about it. Now I'm sooo paranoid.
I ran it up to pick up my kids and it stayed in the usual temperature range. After I got my daughter, about five minutes, when I turned the key it kind of choked but started and the temp was just above 1/2 but immediately dropped to the normal range. I drove it all the way home in stop and start traffic and the temp stayed below 1/2.
I'm stumped but still worried beyond reason about it being a head gasket. I live in a really expensive area and that would probably cost me $3K. I can't afford a new car. I really want to know what this is so I can relax about it.
Anybody have any idea what this could be other than a head gasket? Or do I just do what both mechanics said and keep driving it and keep an eye on the coolant level and temp and don't worry unless it overheats or comes up with another symptom?
Thanks in advance.
Thanks in advance.
