Have seen some stuff on it but so far nothing. Seems like that's a depreciation of the Corvette name and history. The Corvette is a unique product and to soften that image with a SUV just doesn't feel right. I'm a Corvette owner and I really appreciate what the Corvette badge means. But companies will do what they want to do.Aren't they supposed to make a corvette SUV ? Should be interesting if they really do.
Not at all. It's not far off from our 2020 Cadillac XT4 2.0 Turbo.Is anyone else disappointed with the lack of acceleration with the 1.5 L turbo engine?
Unlike a typical acceleration procedure where you accelerate to road speed, back off the throttle and the trans will shift to it's highest gear, the Equinox will not do that once you're past 62 mph. It will remain in 7th gear, which at 70 mph is 2200 rpm. 8th gear is 1800 @ 70 mph. What I do is accelerate to 58 mph, back off and let it shift to 7th, then slowly accelerate to around 61-62, completely back off the throttle. It will shift to 8th every time. Then slowly accelerate to road speed. The catch here is if you try to accelerate too fast it will down shift to 7th, which means that's where you'll stay. The TCM is programmed not to enter 8th gear while accelerating through the lower gears and definitely will not shift to 8th if road speed is above 62 mph, and throttle % is more than 0. Once in 8th with will remain there until you either accelerate too fast to pass or slow down to a point it downshifts when you're picking up speed again. Either one of those actions will put it back in 7th and it will stay there. This approach may save some fuel since you're never really racing the engine as you merge into traffic, but because you're entering much slower than surrounding traffic you may get some nasty stares from other drivers. I live in a rural area so there's not a lot of traffic but in town (Green Bay) you have to pick your spot. You can always force it using the paddle shift, but to me, that kind of defeats the purpose of an automatic transmission. Using the above technique I'm getting 8th gear 90% or more of the time. Hope that helps.Gary, care to comment on the technique that you use to consistently get it to use 8th gear ? I can sometimes get it to use 8th gear, but not consistently. For me, it is hit or miss.
It was never intended to be a sportscar.I too am disappointed. It's very slow to downshift. When I punch the gas, I could almost take a nap before the car accelerates. On neighborhood 35 mph roads, it sounds like it's lugging. I'm frequently doing a short stab of throttle to force a downshift. The 2 liter was no longer available when we bought this '22 Premier.
On the highway, it's great. The rpm is up and the turbo is spinning, so goosing it while doing 60 or more feels good.
Not if you're working up thru the gears. It will if you turn on ERS, up shift to 7th and then 8th with 0 throttle. I've found it won't if road speed is above 70. But the trick is throttle position at 0%. You can't be accelerating. It's a goofy set up. Once in 8th the thing will run along fine. Set the cruise at 70 - 72 and it will run 8th gear all day long. On a recent trip it got 34 + mpg. Ran in 8th all the way.Using the paddles will not make it go into 8th at speed.
