Brake & Air Bag Warning Light on.
Panoramic PEI
Prince Edward Island, Canada
Anyone have had any experience with these issues?
No ABS warning light on, only the Brake (Red) warning light on. I am guessing if there is a sensor for the Parking Hand Brake, the sensor could be defective since the brakes & Hand Parking brake are functioning perfectly & the Brake Fluid Level is fine.
The Air Bag Light stays on, that one has me entirely baffled. Hopefully it isn't the Air Bag Sensor = $$$$, only for the part, replacing it can not be more difficult than replacing a Headlamp Bulb.
I get no chime if I leave the Key in the Ignition & open the door.
Other than that the Driver's side Front speakers only, have no sound, tried another speaker to test for sound, guessing one channel on the Stereo itself is defective, I checked wires behind the Door Panel & behind the Stereo, all looks normal & very clean.
Any Fuses related to the above issues are Fine.
Thanks
I thought I knew what you had going on until I read further. Have you worked on it anymore?
It'll be interesting to find out what the issue is.
