2018 Equinox, need help finding a ignition on power source
pktwatch
Installing Dash Cam and need a source that is on and off with the key. Sounds easy but in this one is not! All of the fuses under the dash are hot. Went to the rear panel and found 3 that were keyed so I ran the wires and got it all hooked up. Well they are wires for a trailer and cut off (I think with I go in reverse, need more testing) None of this makes sense. Done research and some say the key fob turns everything on as you approach so I left it in the house. No help.
Anyone ran into this with the new Equinox and have a solution? Thanks!
pktwatch
I am still searching for a keyed power source from the rear fuse panel. Has anyone figured this out? To took it to a audio installation shop and had a friend who works on police car electronic installations take a look and they are stumped. All I need is a source that is on with the key from the rear fuse block, sounds simple but no answer yet!
