sandhammaren05
- Joined
- Oct 8, 2024
- Messages
- 3
- Reaction score
- 0
My A/C went out and a non-Chev repairman said it was a 'sensor'. In any case the A/C worked again but the blend door started knocking intermittently. I replaced the actuator with an O'Reilly one and tried various internet prescriptions for resetting the actuator, all to no effect. The A/C works fine whether set for air recirculation, or not and the only way to eliminate the knocking is to set the control for open airflow, and then the A/C seems to work as if there is recirculation. I.e., it knocks when set on recirculation and is quiet when set on open air flow.
