2010 Equinox TPMS
walkerpl
Coming back from the dealer, the Service Tire Monitoring System warning appeared on the Display Information Console. The tire pressure display only shows pressure for the rear tires, with no numbers at all for the front. Seems odd that two sensors should go bad at once. Should a system reset be sufficient to restore the sensor display?
mswerb
Cleveland, Ohio
If the dealer removed the front tires without resetting the TPMS this is going to happen. It should be an easy fix and can probably be found in your owners manual on how to do it.
