2012 Equinox engine problem
This is a discussion on 2012 Equinox engine problem within the 2010+ Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
2012 Equinox 2.4L 4 cyl. AWD 133K miles I know this subject has been beat to death but just want ...
Old 05-31-2017, 06:45 PM   #1 (permalink)
tns58 is on a distinguished road
Default 2012 Equinox engine problem
I know this subject has been beat to death but just want to put in my two cents( which will be all I have left after the equinox is done with me).
But first I would like to say the 2012 Equinox is a fine vehicle and a pleasure to drive except for the engine. Bought used and then started noticing oil disappearing( yeah most of you know the story). Took to dealer, oil consumption test done, dealer says normal use. No help from the dealer at all. Consumption got worse, went from 2 quarts to 4 quarts between oil changes. In the meantime had to replace catalytic converter and a cracked exhaust manifold and now have a check engine light indicating O2 sensor problem, gas mileage dropping too. After researching, these problems seem to be caused by the oil use issue. Engine probably needs new rings and pistons($2500 at the dealer) but other internal damage may be present so cost may be even more. I found on the internet that GM had extended warranty for this issue but only up to 7 yrs or 120K miles. So, I am out of luck and dealer did not mention this as this started while still under 120K miles. Consulted a honest mechanic friend and he says it would be cheaper to replace the engine. He quoted $1800 for engine and labor, turn key job, with a one year warranty on everything. I trust him. Only choice is to replace engine or get rid of the car. So, trying not to be long winded and boring this vehicle will cost me a lot. I wish GM would do something. I am filing a complaint with them and see if I get any kind of response. Very disappointed as it is a nice car but will be my last GM. Thanks for listening to my rant.
tns58 is offline   Reply With Quote
Old 06-01-2017, 04:45 PM   #2 (permalink)
Tx12nox is on a distinguished road
I just got a recall for my 2012 2.4l for oil consumption... Like this past week
Tx12nox is offline   Reply With Quote
Old 06-01-2017, 06:41 PM   #3 (permalink)
Richard is on a distinguished road
The engine costs more than that even a Recycled from China. He might be rebuilding yours which is what that sounds closer to. The problem with the 2012 is the rings and fuel pump, I just traded mine to keep from arguing with the dealer. A rebuild for $1800 will be worth it if you get another 100,000 miles without the oil smell.
Richard is offline   Reply With Quote
Old 06-01-2017, 07:46 PM   #4 (permalink)
How did you get it?
Old 06-01-2017, 07:51 PM   #5 (permalink)
He says this is a completely rebuilt engine not brand new, 1 yr. warranty on everything, that he is quoting me. I guess he is giving me the friends and family discount?
Old 06-01-2017, 07:59 PM   #6 (permalink)
How did you get it?
In the mail and another for a fuel sensor being mounted below the frame
Old 06-01-2017, 08:23 PM   #7 (permalink)
Old 06-01-2017, 08:31 PM   #8 (permalink)
I got the one about the fuel sensor this week but have not seen the on eabout oil consumption yet. My vehicle is past the 120K mark. I wonder if they would still honor it for me?
Old 06-01-2017, 08:32 PM   #9 (permalink)
I would hope so but I have a feeling they won't. I got that one the week before the fuel sensor.
2015 Equinox Transmission Problem kglidden5 2010+ Equinox General Forum 1 11-13-2017 03:48 PM
2012 Equinox Washer Fluid problem mattysoxfan 2010+ Equinox Maintenance 3 09-12-2016 04:30 PM
Check Engine Code - P0442 (38k Miles - 2012) AllenGot 2010+ Equinox Maintenance 3 02-28-2016 10:09 PM
2011 Chevy Equinox Problem ali68521 2010+ Equinox General Forum 9 11-10-2015 08:41 AM
2011 Equinox Ipod problem nielsonj Audio & Electronics 9 01-18-2012 02:15 PM
