2010 Equinox V6/LT/AWD Power Steering Out
This is a discussion on 2010 Equinox V6/LT/AWD Power Steering Out within the 2010+ Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
Hi all - I have a 2010 Equinox AWD LT with 3.0 V6 that has had the power steering go ...
Old 08-30-2015, 11:22 AM   #1 (permalink)
billyi1 is on a distinguished road
Default 2010 Equinox V6/LT/AWD Power Steering Out
Hi all - I have a 2010 Equinox AWD LT with 3.0 V6 that has had the power steering go out at ~48K miles. There are no signs of leaks & the PS fluid reservoir has the right amount of fluid (full). There are no warning lights that have gone on, there are no strange noises...simply that it requires muscle to steer at all speeds. I've looked online for advice but it all applies to the 4 cylinder models having a failed midi fuse (80A) linked to a electric power steering motor. The fusebox in the 6 cylinder doesn't even have the 80A fuse so that would confirm the V6 doesn't use the electric PS motor. Before I end up taking it to the repair shop, was hoping someone had some advice/insights they could share...thanks!
billyi1 is offline   Reply With Quote
Old 08-30-2015, 09:21 PM   #2 (permalink)
I haven't heard of this being an issue with the 4 cylinders let alone the v6. I do know there was a time around 70-80k that ours was acting a little sluggish so I replaced the existing fluid with AMsoil synthetic and it has been easier than it was from the factory.
Keep us updated with any progress with this issue!
Old 11-08-2015, 09:43 PM   #3 (permalink)
The V6 has belt driven power steering pump. Try bleeding the system. Verify the fluid is at max cold level. Turn the car on and turn the wheel from stop to stop 20 times. Then recheck the fluid level. Repeat 2 more times.
2010 equinox lt v6, power steering out
power steering message bawbeebee 2010+ Equinox General Forum 4 10-19-2017 09:34 PM
B&I Steering Wheel for Chevy Equinox 2014 carid CARiD.com 0 09-17-2014 07:48 AM
2011 chev equinox awd v6 steering noise!! Jhayne 2010+ Equinox General Forum 4 08-25-2014 09:17 AM
2010 Chevy Equinox v6 3.0 Reduced Engine Power/Replace Stabiltrack dietz4ibanez Engine & Performance Modifications 6 07-08-2014 06:01 PM
Need power foldaway mirrors for 09 Equinox Sport 09_Equinox Exterior Modifications 6 05-01-2012 08:49 AM
