What kind of fuse controls turn signal indicator on drivers side in 2011 Equinox
beschaus
What kind of fuse is used to control the driver's side turn signal indicator and brake light? It makes a fast-clicking noise when I use the left indicator and the indicator itself doesn't work. The light itself works when I use remote door lock to unlock/lock door, so don't think its issue with the light.
Normally when you have a fast click with a turn signal it is a indicator that one of the bulbs are burned out. I would check the ambient light in the front head light as well as the lights in the tail light.
Bicdaddy
NH
There is a turn signal relay. It may need to be replaced... it's probably one of the more expensive relays in the vehicle.
