RPM's surging at idle after head gasket job
rft607
05 Equinox. Did a head gasket job and everything went smoothly. Started it up when finished and it ran fine. After reaching operating temperature, the RPM's will start to surge until it stalls. It starts right back up and will happen again a few minutes later. No codes present and it's smoking out of exhaust still, only not as bad and it doesn't smell like coolant. Smells more like it's running rich. Also seems to be a slight backfire when I rev the engine. Any help is greatly appreciated, thanks.
3fingers
Make sure to have a leak down and compression test to have an idea of your engines health.
ThePapaJohn
Richmond, KY
Still having your problem?
Compression check should always be performed pre and post head gasket work. Find out if your introducing an issue or bringing to light a previous minor one....
Shane
Did u ever resolve the problem? I just did a 2005's head gaskets and have the identical problem? Please advise
