Ignition Coil Bolt Shear in Valve Cover Gasket
ananaBanana
F945EC9F-6089-4B56-9DAE-FDBF42764563.jpegOn the right of the spark plug, the bolt sheared and is now stuck. Currently I am using wd-40 to loosen it up a bit before I try using a screwdriver; if that fails I’ll use more wd-40 overnight and try again.
If that doesn’t work I’m going to try getting some 3/8 bit extractors and try that, if that fails, i’m going to use a dremel and some drill bits to notch a hole into the bit and tap it out, if that doesn’t work. Well, idk any suggestions? I suppose I’ll figure it out, it doesn’t really matter but it still bothers me.
Thank you!
