help seriously
icu1954
i have a 2016 equinox with 2.4 ecotech, my problem is my intake cam shaft sensor is leaking from where it is mounted in the head.I have changed sensors..still leak.I have changed rubber gaskets ...still leak.I have bought a new sensor just to get the rubber gasket...still leak.What else could i do to stop this annoying leak.If not tended to it will wet my sensor and cause problems. Thank you
Did you use the correct OEM ACDelco sensor and gasket, or aftermarket?
