Flat Tow battery discharge
SRFoster
My 2019 AWD can be flat towed and manual says no fuse needs to be pulled but needs charging. I have done this but the battery still drains on long trips. I have worked on this for three years and have found a fix. I was looking at the draw from each fuse and found that the radio fuse F42, from the inside fuse box, had a large draw even with the radio off. After removing the fuse, I drove 8 hours and the battery stayed fully charged. If you are having a discharge issue with the 2019 and newer Equinox, try pulling the F42 fuse. Worked for me.
2019 Equinox
I have a 2019 FWD, having same problem, we have a charge line, and have towed 10,000 miles or more, after have problem, I have stopped every 2.5 hours and ran the car for 10 to 15 minute, last time out, after driving 3 hours battery was dead. May try pulling F42, thanks for the informatio.
Jim-Carol
Oregon Coast
Newbe here.. Have 2018 Premiere. Was towing fine with charge line for 4 to 6 hours. Now doesn't and have to jump. Battery would go to 12.2 volts when sitting overnight but still start. Replaced battery yesterday. Did some trouble shooting yesterday . Charge line had 14 + volts but battery after driving car all day read 12.2 and would not take any charge....seems like battery monitor system is not letting take charge. Wired charge line to one of the empty spaces under battery cover. Any thoughts? Thanks
Gatewood
We pulled F42 fuse on our Equinox, drove 225 and it started right up!!!! So glad for the information. It's been a frustrating problem. Thanks for the fix!!!
chasfm11
We have a 2018 FWD Equinox and have towed it since 2019. The first few years, there wasn't a problem and I could drive the motor home 12 hours a day with the Equinox coupled. Three years ago, I arrived home to a dead Equinox battery and I have not been able to keep the Equinox battery charged while towing since.
I have learned the the onboard charging system deliberately does not bring the battery to full charge. It is a design "feature". I followed the instructions for running the charge line from the tow bar manufacture where I bought the kit but now wish that I had used a heavier wire than the one they provided. I wondering if the current flow across the charge line is not enough to overcome the current loss on the Equinox. Also, I wonder if something that was supposed to "time out" within 30 minutes of starting to tow is no longer timing out.
My plan is to put my Equinox in towing configuration, wait 30 minutes and then measure the current drain. I will then try to see how much current is flowing across the charge line. I've carefully checked all of the charge line connection points for any corrosion but this could be a poor ground problem between the motor home and the Equinox. I'm going to see what fuse 42 does in my model and may pull it during my testing to see if it makes a difference. I appreciate that tip.
I greatly appreciate any other ideas. FYI, We are in Texas and it is sometimes necessary to run the genset to operate the roof air conditions while driving. I've wired the charge line to the genset/converter output temporarily and the Equinox battery stayed fully charged. I don't understand the possible difference between the converter output and the alternator output from the motor home engine. The diesel alternator is high capacity - 200amps
Jimer
I found out that the AGM and CPU does not like charging from a lead acid battery charger, ot a smart charger. A new AGM-LITH charger is smart so the 3 of them talk to each other for proper charging. That may be why our 12v wire from the motorhome to car is not very effective.
Goodscout
Peosta, IA
We tow a 2020 Equinox and have a charging line hooked up. Dead battery after a couple of days. Does pulling the radio fuse continue to help you?
LewL
Reno, Nv
I'm new to the forum and my wife's 2025 Nox has less than 3k miles and the batt went to 3.5 volts sitting in our garage. Had it towed and the dealership couldn't find any problems.
I'll start a thread about the seat memory soon.
LewL
chevylou
Florida
Do you pull the radio fuse before or after you do the owners manual setup to flat tow.
kodum
Jacksonville, FL
So, you do not need to disconnect either battery pole? It's as simple as that???
Davebwb
Disconnect the positive side of the battery and your drain issues go away.
LewL
Reno, Nv
Our 2025 Equinox RS has had electrical problems not related to being towed. The battery has gone completely dead a few times. Dealer said just drive it more/longer trips. Just got a new battery, so guess we'll see what happens. The dealer is NOT good with the newest electronics.
