Factory Fog Lights
Georgia Nox
I've installed factory fog lights in my 2012 LT NOX along with the factory light switch that's incorported into the turn siginal module. I know I have to get the BCM programmed as part of this installation to make it all work like a factory install. I've also made a neat replica wire harness plugged into the fog lights all the way up to the fuse box under the hood. Question: Does anyone know the exactly locations where these wires plug in on the underside of that fuse panel? I see the fog light fuse and relay already present on the topside, but not certain of the exact plug-in locations on the underside. Anyone out there done this? If so, sure could use your help. A clear photo of where they go would be a bonus! Thanks!
