Does 2020 Premier have ANC? What fuse?
mdub88
I have the manual and don't see any fuses labeled as active noise cancelation or ANC. Does the premier trim not have it? Is there something comparable installed, and if so, what fuse?
Lots of road noise on highway..been like that for a while and saw ANC mentioned, so I'm investigating replacing the fuse.
It works with the sound system from what I understand. There is a service bulletin for older models about blocking the rear speakers. That can make the system ineffective.
CoolDad
Is there a way to adjust it?
ravenblack67
ANC is designed to reduce engine noise at low rpm. It is not designed to reduce road noise. I have a 2020 Equinox and reduced road noise by adding sound barriers under the back seats and in the spare tire area.
Miguel
Toronto
What type of sound barriers you used on those areas?
Vondoman
Was the sound barrier from an adhesive roll? Brand? Tks
