Bolt pattern
Has 5x120 BP with 14mm studs. Almost all cars use 12mm studs. Like bmw, Camaro, and wonder if those wheels will fit or not? Not sure I’ve seen it discussed.
of course center bore, offset and width matter. its the mounting I am thinking of.
Seems the 06 odyssey has 5x120 and 14mm studs but bore is 64mm while the equinox is 66mm bore. the equinox wheel will fit an odyssey but not the other way around.
was looking for temporary rollers. Not long term.
