Sunroof 20k fix
sunroof nightmare
hi everyone, brand new here so sorry if my etiquette is off (posting 1st day). My 2020 equinox sunroof opened last week and would not shut. i took it to one mechanic and he couldnt figure it out so brought it back to the chevy dealer i bought it from. They said it was a leak, showed me the puddle in the spare tire well, they told me this leak shorted the motor/electronics and said there was probably mold. They just gave me the estimate and it will be 20K worth of damage to replace sunroof/parts/interior (mold). it seems like a defective part (no accident caused this, it really just opened one day and wouldnt shut) and my auto insurance wont cover (not brought on by an accident), the warranty will cover maybe 7k worth of fixes, and my GAP insurance wont kick in since it is not a total loss/wasnt caused by accident/weather (tornado etc). does anyone know what i should do here? i owe 18K on the loan still so 20K in fixes is absurd. i did not notice any mold or smell any (i know mold could be invisible/no smell). i am thinking just have them shut it and deal with it when it re-opens again. and again. lol.
SteveK
20K, wow! Does that come with new tires, 🙃
If I had this bad luck I would start by removing the headliner (as carefully as you want) and expose the operator for the sunroof. I would check for power to the motors wiht volt meter to determine what/where the non operation is.
In previous posts on sunroof leaks the fuse box was mentioned as a possible place for a short created by the water leaking. If it opened, there was power, did the relay to close fail or did the roof jam.
BTW, you did check all fuses.
Severum17
Thats a ridiculous estimate. I would check at another dealer. Did you get it closed? If so, I might just leave it. I cringe every time I open mine just for that reason. I dont use it much.
Well-known member
yikes. close the damn thing and disconnect the motor. Dry out the spare tire well, spray in there with some mold treatment and call it a day??
pipwax
Atlanta
I have 2010, when I had that problem I purchased some dry lube and stayed the tracks and no more problems closing.
SteveK
I have a 2019. Yes water caused the main retraction motor circuit board to fail. It may also be the switch(s).
Here is where I am at. Mine is in closed position so have not rushed. There are two motors under the headliner. Passenger side retracts the headliner, the driver side retracts the sunroof. The driver side has the circuit board and is the master which also tells the passenger side what to do.
I pulled the master (driver side) motor out and took it apart. There I found corrosion from water. How water got in there is a mystery as it is not related to the tire well water. Best guess is the worm gear picks up water and deposits it onto the internals.
Anyway, I ordered to replacement motor, but I ordered the wrong motor and are currently selling a Camaro motor as it is well past returning on amazon before I checked. That is on me.
HERE is a bulletin. This appears to be the correct part# but I have not received so make sure yourself.
Sunroof Motor with Control Module - GM (22762630)​
