Negative Battery Cable/Battery Saver Active
tcave44
Replaced a dead battery last weekend on 2010 Equinox 4cyl. and since then, been getting Battery Saver Active warnings within a minute or two of startup. Garage couldn't figure it out as alternator is charging battery normally. I kept mentioning the crazy amount of corrosion on the negative and asked about the battery current sensor since it seems like that is a potential problem. He said he's never once had to replace that sensor but when I asked about doing it and swapping a whole new negative cable in there, he said he'd do it but wasn't sure it would fix it. Well... took it home to think about it. Figured I'd spray some protector on that negative terminal to prevent corrosion. Pulled back the rubber flap to find this...
Looks to me like in all the cleaning and dis/re-connecting, the smaller wire (ground wire, right?) has snapped. I guess the corrosion got to it after all. Don't know how the garage didn't notice this. Anyway, this is almost definitely responsible for the Battery Saver Active alerts, yes? Suggestions on what to do with it? Does that just get crimped under that side terminal bolt? Should I just get a whole new cable? I can't find any images of how that is connected correctly. Any help is appreciated. Oh also, am I gonna do any damage if I drive it without that connected for a few days?
tcave44
UPDATE! I just snipped below where the connector corroded away, stripped the wire, and wrapped it around the nut/bolt where the connector was fastened. So far so good and no Battery Saver Active alert after a half hour of driving. Sprayed some battery terminal protector all over the terminals and hoping this'll last a while. Hardest part was stripping the wire since there is not much slack in that thing at all.
Terrywhite
it's a shame no one replied to this at all.
I had the same problem and cleaning it all fixed it right up. I also snapped that same ground wire which to this day I have no idea what it's a ground for.
II'm having AC problems now. Oddly in the morning hours it works perfectly but, later in the day when you need it most you can hear the clutch engage and it will turn maybe 3 full revolutions then the clutch disengages and you got it... no AC.
Not meaning to swipe your thread. I just added the AC part because it was the very next problem.
tcave44
I wish I had some insight for you on the ac. On my Equinox, the manifold went for the third time a couple months after this... and then before I could even get it fixed, the transmission went. It's been sitting in my garage waiting for me to unload it somewhere. No way I'm putting transmission money into this car.
Terrywhite
Ours is in pretty good shape and had only recently started with some off the wall things.
We have the LTZ Model and I've been seriously thinking about finding a Mazada 3 or maybe even a Mazda 6 and try doing a straight trade. It's paid off now so I'm not really ready to start pouring cash into it.
Teezbeez
Has anybody actually replaced the Battery Current Sensor? If so ---- how does it fit over the terminal end of the negative battery cable?
ricooryin
First I will say "Hello all!!!". My aunt's 2013 Chevy Equinox LT 2.4L will not start. I found that
1. the key broke from the key fob. I bought 2 replacements from Amazon (search MechanMagic when searching for keys) and swapped over the guts of the original to one of the new ones. Youtube has a guide on how to replace open them and swap over the parts. Must make sure not to break the Transponder antenna so follow the videos. They come with batteries installed.
2. I have order from Amazon GM Genuine Parts 20955244. I will let you know if it repairs the no start. If you search the part number on Google and look at the images it will show you that it comes with everything needed to replace the cable (with sensor).
Joseph Davis
Puryear, Tennessee
What part number is it?
deadpool
Newmarket
Whw
View attachment 1774View attachment 1776
Were is the wire located, i cant even find my ground strap🤦‍♀️
