Headlight, Parking lights control
Wazoomr
I'm very dissapointed with the automatic headlight & parking light controls. To preserve the life of the LED bulbs, the automatic headlight controller should've been designed to use the center dash light sensor to ONLY turn on the headlights when it's dark. I think this is intentional so the dealer service centers can make more $$$ by charging customers $800 to replace a blown bulb which is very difficult & expensive to do. The entire font fascia of the vehicle must be removed to change the headlight bulb. The other problem with the headlight control is that if you set it to to either of the non-auto modes (headlights, parking lights) they remain on for 10min after you lock and leave the vehcle. There should be a setting that allows the user to change the turn-off delay.
