Having problems with my 2010s braking system.
Jade
Brakes will randomly and usually short term start pulsing the front wheels just out of the blue then quit and all is good till next time. New front wheel bearings(sensor bands), new rotors, new calipers and pads. Pulling the "ABS pump" seems to eliminate the problem. First time it happened I thought a tie rod had come loose and I was going to loose the whole front end but then it started to go away and was fine for a week or two then it hit again. Anyone have any ideas. I am thinking of changing the ABS pump.
Write your reply...
