Intermittent problem w/ 2013 Equinox. Electrical system blanks out, then car starts fine after a while. Throws P0411 code for a few days, drives fine.
cooperbl7
I am having an intermittent problem with our 2013 Equinox LT (118k mi.), which has occurred twice so far, ~5-6 weeks apart. The car happened to be started with a remote start each time, and it drives OK for a bit, then (1st time when stopped in a turn late, 2nd time after stopping in a parking lot) the entire electrical system blanks out. Screen goes blank, key doesn't do anything (no starter clicks, etc), car is just utterly and completely blank / dead / immobile. Then suddenly, miraculously, the car starts fine (after a while of being blank), and runs just fine.
It seems perhaps the whole electrical system must be rebooting itself, or something, but it is not as if there was a battery disconnect. The clock and everything shows the right time and everything else works fine when it comes back to life. The battery tests out fine (fairly new, ~1.5 years), and I'm told the alternator is fine, too. The check engine light comes on for only a couple of days each time then goes away, was never blinking. Car drives fine otherwise.
Took to a repair shop for diagnosis, and the only engine code they found was a P0411 code ("secondary air injection charge"); they also found no obvious issues with the electrical system, fuses, etc. Recommended taking it to the dealer, but I thought I'd post here and see if anyone else ever experienced the same or similar issue.
We can DRIVE it, but I just don't trust it for long trips, and it seems risky even driving locally (not sure if it could occur while driving down the road, instead of being stopped). Thank you!
Bigmarunga
I am having the same issue with our 2013 Equinox Lt 121,200 miles , mostly highway miles this car has visited 48 continental states. . Replaced the battery 4 months ago. No loose wires or cables. don't really want to take it to the dealer if it something simple.
mathletemccoy
Washington
Did you ever figure out what was going on?
My car has not had the electrical go blank, just have had a check engine light come on and then go off and then back on again..... usually after about 75 miles of driving each time.
Gives a P0411 code.
No change in the way it drives though, just a little concerned that it might be a bigger deal than I think.
4549stiltz
Washinton
I am a retired GM tech after 35 yrs My specialty was electrical and run ability. That being said. I would suggest checking all modules for codes like (BCM) Body Control Module and etc. Some modules is shutting things down. You could be a pain to find. Sometimes it has to broke before it can be found.
