Creaking sound right before coming to a stop 2026 Equinox LT
Magsie
Hi there, any updates from you? I took mine to another dealer and they had another 2026 come in the same day with the exact same issues. It’s still at the dealers and I have a loaner for the foreseeable future.
Imalabil
Nothing yet, I'm trying to work out with my daughter when she can take the car to the dealer and let them have it for an extended period.
Magsie
Wanted to provide an update to everyone in this forum. I worked with a dealership that worked with a GM engineer to get answers. It’s the front lower control arms that need replaced. I had that done on 8/14 and today 8/18 I would say 96% of the sound is done. I do believe the back arms may need swapped out as well, but it is DRAMATICALLY quieter now.
Imalabil
Great that you were able to get yours addressed! I've forwarded this and will need to have my daughter get it taken care of.
Magsie
Update: after a week with the new arms, the sound came back. A GM field engineer came out to the dealership and replaced the arms again, concluding that the sound was still there after. He drove another on the lot and sure enough, the sound was in that one as well.
I’ve pursued a buyback with GM via lemon law. It seems like it’s a common issue with the 26s, coming from the control arms but not fixable at this time.
Imalabil
Update from the dealership, they replaced my brake pads and resurface the rotors but the noise is still there. Evidently new control arms isn't the solution either. From the experience you have shared. I'm wondering about the strut mount bushings.
Magsie
Thanks for the update. GM is buying mine back according to the lemon law here.
Imalabil
The response I got from the dealer and GM is that there is no fix and no explanation on why my 2025 did not do that.
macdowae1
Fl
With my 2026 Equinox, I am experiencing a creaky sound from the front end when braking right before coming to a full stop. It also occurs when gently accelerating from rest. It's been to two dealers and they hear the sound but can't seem to diagnose and repair it. All I am getting from them is "cannot duplicate". Has anyone else experienced this? When my daughter had her 2025 she didn't notice this at all, but with the new 2026 it is stumping the dealers.
I have this same issue with my 2026, I was starting to think I was crazy and couldn’t really describe it. But your description is spot on. Did you ever get it fixed?
Imalabil
No, the dealer contacted GM and was informed that they all do it. I need to call and ask if they have any updates.
wilamowski3
I have a 2013 Equinox. I spent a good two months searching for a vibration issue. I creaked before I started work om the other issue and it creaks afterward. I have replaced struts, lower control arms, engine mounts, stabilizer links, half shafts, wheel bearing, brake pads and steering linkage rod ends. It doesn't creak going down the highway. It doesn't creak when jouncing the vehicle. It does creak when I turn the steering wheel both directions, but only when the vehicle is on the ground. It creaks when shifting into reverse or reverse to drive. I have tightened everything I can find - no affect. Because it has to have wheels on the ground it's very difficult to get under it to diagnose. I've thought about steering column, but why would shifting gears affect it? Inspected cradle mounts - no wear, all solid. I've examined the stabilizer bar inner rubber bushings. They look okay, but my vehicle is old and rubber does change with age.
