Burning through LED headlights every few months. Cause/recommendations?
hdsalinas
Hi all,
I have a 2019 Chevrolet Equinox (base model) that came from the factory with standard halogen bulbs. Since the stock halogens were way too dim for night driving, I swapped them out for aftermarket LED bulbs shortly after getting the car.
I’ve owned the vehicle for almost 3 years now, and I’ve already gone through 3 sets of LED headlights. The lifespan on these LEDs has been terrible:
  • Auxito LEDs: Failed twice within ~1 year each (first set was replaced under warranty).
  • BEAMTECH LEDs: Lasted only 6 months (became so dim the factory DRLs were brighter).
I'm currently back on the stock halogens out of necessity.
Quick questions for the community:
  1. Is this a common issue on these models?
  2. Is heat build-up inside the sealed dust cap killing the drivers, or is it a voltage issue?
  3. Which LED brand actually lasts long-term in these projector housings?
I have a feeling that the start/stop "feature" is killing the bulbs
Thanks for any feedback!
MADDOG
Exploring Arizona
Community Manager
Administrator
Military
Arizona
You may need some resistors. Google that up and see what they have to say about a halogen to LED bulb upgrade.
Hi all,
Auxito and Beamtech LED bulbs are made in China.
I suspect the bulbs are of poor quality. There are plenty of aftermarket auto parts made in China that are simply junk.
The durability of these LEDs is always a problem. You never know what you're going to get.
I do believe you are on to something with the auto stop/start cycling. Especially if the vehicle has to endure a ton of A/S/S cycling. The surging of current on all the electronics in the vehicle isn't great for it.
