I replaced the shark fin no change. I removed the Radio to check collections in the back of radio all was connected. I tried to reset the radio. No results. Any other suggestions?Most likely need a new shark fin antenna. search forum there was a DIY post
My 19 premiere had static on fm absolutely no stations but AM worked and a new fin fixed it . There are different ones depending on options car has also and maybe possibly2018 Equinox
AM FM RADIO NOT WORKING ONLY STATIC ON BOTH
SATELLITE WORKS CINE AND ALL OTHER FINCTIONS ARE OK
ANY SUGGESTIONS
Thanks for the infoMy 19 premiere had static on fm absolutely no stations but AM worked and a new fin fixed it . There are different ones depending on options car has also and maybe possibly
You have an issue with cable between the fin and the receiver module
