2022 LT: Cargo area rear has missing, black, plastic trim/cover.
Smokin Equinox
Passenger side inner, closest to rear bimper. Went to Dealer. Says Normal WTH? Pix I can drop small toys/balls in there and they go into inner structure! I see/touch" inside of the OUTER rear fender! Are they crazy?? I walked out and said Ill be back. Help! ( light brown shapes in pix are just sunlight shinking thru open hatch)
This is ABOVE Spare tire well. pad/rug......
Smokin
ravenblack67
The same on mine. I filled it with bubblewrap and placed a piece of hard plastic at the opening.
gary255
Michigan
Smokin
I have a 2021 GMC Terrain and it's the same.
CPG
Smokin
That area is where the optional cargo cover is stored when not in use. Check your owner's manual in the cargo cover section (pages 76 & 77 in my 2023 Equinox owner's manual) and it will show it being stored in that area. It is so long that if you didn't have that area open, it wouldn't fit for storage. I got an aftermarket cover and it was about $70. The GM model Is $170. My aftermarket cover will not fit in that area... it's constructed differently then GM model. So if you want to take the cargo cover out and store it like the owners manual shows when not in use, you have to go with the GM cover.
Smokin Equinox
Tks CPG! I got it. But what a silly thing to leave as an option! I already had something fall in there! What is GM thinking these days?? Peace.
Smokin
CPG
Smokin
I think it's a safety issue... There has to be a way to lock down the cargo cover so that it can't fly around in an accident and kill somebody... Read the owner's manual page 76 and 77 and it says that it's a place to "safely stow the cargo cover when not in use". It probably weighs 5 to 10 lb.
CPG
Also owned a 1999 Camaro with t-tops... They also had places to lock them down and stow them when you had them removed, but in the back of the car... Again, so that they couldn't fly around and injure folks in an accident.
CPG
One last point... If you look at your original photo of the area in question, you can see molded into the plastic an open book with the letter "i" for information in the middle of the open book.. that means look in the owner's manual to understand what that area is about.
bagbyjw
My 2022 LS has the same thing, I just keep the cover in place and nothing can or will fall into limbo/space
