2019 Equinox Premier Dim analog Instruments
Dischevelled
Hello,
The analog instruments (speedometer, tachometer, fuel and temperature) gauges in my 2019 Equinox Premier are extremely dim, sometimes completely dark while driving in daylight, yet, the digital display between the speedometer and tachometer is very well lit. When the car is in a dark environment such as the garage, all the gauges are well lit . I've had it to two dealers who found no problems noted. Has anyone else with a Premier version had this issue?
Thanks.
ROBO
Have you tried using the dimmer switch to increase/decrease the brightness? Its a push in spring out type switch on the far left side of the dash.
