2017 equinox radio wiring diagram
blauv
Ohio
I'm looking to use my factory deck and add an aftermarket amp setup.
I'm unsure of the speaker wiring color codes on the neck of the deck to be able to splice in to make the T connection to place the amp in.
Is there a good diagram around that could help figure out what wires are for where?
drifty
The factory amp is under the driver's dash to the left of the steering column.
I have a 2017 Premier. I am in the slow process of upgrading my system as well.
I've never had an issue doing installs
on any car from the 70s, 80s or 90s but
these newer cars & trucks are a bitch. There is an adapter needed for anything,.
An ignition wire is hard to find, finally
found one on the passenger side of the
center console behind a small access
panel there is a smaller fuse panel. FYI-
Not sure how the factory Pioneer system is as I have just the base audio system but the base system I have, the amp runs the front speakers and the factory head unit runs the rear speakers. All I have left to do is swap out all 4 speakers, run new speaker wire from my amps and wire up a 4 channel LOC. Gotta figure out how to crack open the center console to install a bass knob though. Good luck on the install.
