Hi-Beam Bulbs
johns4949
Is there a easy way to change Hi-Beam bulbs on a 2010 Equinox ?
I have changed the Lo-Beams thru the access hole and the Hi_beams seem to be a bit akward to get to.
I was messing around with mine and I removed the plastic valance in the engine compartment. All you have to do is temove the pop snaps. Or you could remove the inner fender liner and get to it that way.
Paul79UF
California
You can access the high beam through that circular access panel in the wheel well liner.
First remove the dust cap that covers the low beam bulb to give yourself more room to work.
Then just reach in past the low beam and feel for the high beam dust cap.
G-Man
I found that removing the tire helps a lot also.
