2008-2009 Chevy Equinox Exhaust Manifold & Gasket Kit for V6 3.4L Driver Side
1ATony
VISIT US HERE FOR GREAT PRICES 2008-2009 Chevy Equinox Exhaust Manifold & Gasket Kit for V6 3.4L Driver Side
FREE SHIPPING IN THE LOWER 48 STATES!!
Our aftermarket manifolds are some of the highest quality replacements on the market!
If your vehicle's exhaust is getting loud and the exhaust noise is coming from under the hood or engine then you may need to fix a cracked exhaust manifold. Replacing a broken manifold is easiest with a direct replacement manifold that will fit correctly and bolt up to you original engine and exhaust system.
Specifications:
Fits LH (Driver Side) FRONT
Manifold & Gasket Kit includes:
(1) - Exhaust Manifold
(1) - Exhaust Manifold Heat Shield
(1) - Input Manifold Gasket
(1) - Output Manifold Gasket
(2) - Manifold Studs
(2) - Manifold Nuts
Replaces dealer part number: 12587594
Direct replacement
Replaces original manifolds that are cracked from thermal expansion and contraction
Strengthened and redesigned in the vulnerable areas of failure
Fits models with V6 3.4L Engine only
Now you can buy a high quality exhaust manifold that is built to strict quality control standards for less than the price at the dealer. REPLACE your broken, warped, or cracked exhaust manifold now with this great fitting, alternative. This exhaust manifold is a great replacement and has good cost savings over a dealer unit.
Lifetime Warranty
This item is backed by a manufacturer's Limited Lifetime Warranty. In the event this item should fail due to manufacturing defects during intended use, we will exchange the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
This part replaces:
HOLLANDER #: 327-02195L
OE #: 12587594
DORMAN #: 674-917
