2005 - 2007 Chevy Equinox Front Lower Control Arm with Ball Joint Pair
1ATony
CHECK HERE FOR GREAT PRICES 2005 - 2007 Chevy Equinox Front Lower Control Arm with Ball Joint Pair
FREE SHIPPING ON ALL ORDERS!!!!
These replacement front lower control arms are just what you need to bring back the safety and integrity of your vehicle's suspension and steering.
Specifications:
Comes as a PAIR
Fits both LH (Driver Side) & RH (Passenger Side) FRONT LOWER
Replaces dealer part numbers: 15780423, 25878028, 25878029
Includes ball joints
Direct replacements
Built to strict quality control standards
Worn ball joints can cause excessive front tire wear, popping or creaking in the front end, extra play in the steering system, and pose a serious safety concern. Replace loose or worn ball joints with our quality replacement.
One way to diagnose a loose, or warn ball joint, is to jack the car up, so the wheel is off of the ground, then have someone try to move the wheel in and out. While they are moving the wheel check the ball joint for play, if it is moving you probably need to replace it.
Remember whenever you are replacing any front end or steering components you should have your vehicle professionally aligned as soon as possible. This will ensure proper tracking and even tire wear.
1A Auto Company Warranty
All parts are covered by a 60-day 1A Auto warranty against defects or failure. In the event of a part failure, a replacement will be shipped out at no cost and a pre-paid shipping label will be emailed to cover the cost of returning the defective part back to 1A Auto.
