Ignition Key Stuck Cannot Start Car
This is a discussion on Ignition Key Stuck Cannot Start Car within the 05-09 Equinox General Forum forums, part of the Chevy Equinox General Discussion category!
Can't remove ignition key, it will no come all the way back to off, just moves between acc and start. ...
  • 1 Post By rcchevy
Old 08-23-2016, 01:29 PM   #1 (permalink)
rcchevy is on a distinguished road
Default Ignition Key Stuck Cannot Start Car
Can't remove ignition key, it will no come all the way back to off, just moves between acc and start. Have lifted the front of the car and moves the steering wheels to each extreme but key won't come out.
Shifter stuck in park. Have pushed the Equinox about 4 inches forwards and still cannot operate key nor shifter. Looked up Torque Lock in owner.s manual and followed all the instructions.
Kind of desperate right now as one of my windows is down.
2008 Equinox AWD.
2008 Equinox LTZ AWD
3.4L 6 Cyl, 5 Speed (Aisin F33-5)
(Rebuilt Title, owned since May 8,2015 with 58810 miles)
rcchevy is offline   Reply With Quote
Old 11-12-2016, 12:23 PM   #2 (permalink)
jmarzo is on a distinguished road
Hi
Having the same problem with my 2008 Equinox.However if I wait 10 to 15 seconds or so I hear a click like a relay or a solenoid actuating.I can then turn the key to OFF and remove it.Have you or anyone else found out what the problem was?
jmarzo is offline   Reply With Quote
Old 11-12-2016, 09:00 PM   #3 (permalink)
mswerb's Avatar
My 2007 doe this every once in a while. Try pushing the key in, and then turning it to the off position.
Old 11-13-2016, 11:31 AM   #4 (permalink)
My problem is intermittent also.I tried what you said.It didn't work.I even tried squirting lubricant into the lock opening.Didn't work either.There seems to be an abnormal time delay,15 seconds or so,after which I hear something click,probably the ignition lock solenoid.This allows me to easily turn the key to off.
Old 08-03-2017, 07:27 PM   #5 (permalink)
c927hris is on a distinguished road
If the battery is dead it locks your key. Jumpstart your car and remove it if it is dead.
c927hris is offline   Reply With Quote
Old 09-12-2017, 07:02 AM   #6 (permalink)
Default (Solved)
Dead battery was the problem. Thanks!
The Tireman likes this.
Swapped BCM, Car Won't start. Please Help! docstoked 05-09 Equinox Maintenance 2 08-10-2017 10:37 PM
Key Won't Come Out of Ignition kistnerme 2010+ Equinox General Forum 1 02-09-2016 10:13 AM
Can't remove key from ignition Crystalb2010 2010+ Equinox Maintenance 3 09-18-2013 12:14 AM
Add Remote Start to Nox LS? nolimits76 2010+ Equinox General Forum 14 04-13-2012 07:42 PM
Remote start- No start Z_Ghost 2010+ Equinox General Forum 3 01-15-2011 11:14 AM
