05-06-2013, 05:11 PM
#1 (permalink)
2007 equinox LS wiring help
I need some help with some wire identification or just some suggestions. Im trying to install after-market heated seats into my LS, I have the elements in the seat already, the switch installed, the wiring ran just im having an issue with actually connecting the correct wires. I have my ground wire connected to the ground that runs off of the stock stereo and i have the fused wire running off of the Onstar fuse (My LS does not have the Onstar system, just the wiring). I need an ACC line, also I forgot to mention I have the wires ran into the center console area. From what i've read on the internet, the stock stereo does not have an ACC/Ignition wire but I do know that the power window system does. My issue is I dont know which wire is the ACC wire on the power window switches. I was hoping someone could tell me which one is or maybe help me with a simple solution to this issue.
