Audio & Electronics
New 17 Nox 4cyl LT. Adding an after market sub
This is a discussion on New 17 Nox 4cyl LT. Adding an after market sub within the Audio & Electronics forums, part of the Equinox, Terrain & SRX Modifications category!
Hi All, I've been reading a lot here in regards to adding a subwoofer to my new leased 2017 Equinox ...
Old 02-08-2017, 06:53 PM   #1 (permalink)
kireol is on a distinguished road
Default New 17 Nox 4cyl LT. Adding an after market sub
Hi All,
I've been reading a lot here in regards to adding a subwoofer to my new leased 2017 Equinox 4cyl LT with MyLink and ANC. And there appears to be multiple ways and was wondering what's best.
Here's what I have:
12" Image Dynamix Sub in a box that fits in the back.
750 rms Rockford Fostgate amp
Wiring hookup kit with 4 gauge power wire.
Low level line converter.
So here are my questions:
1) What is the best way to get a signal to my sub amp? Use the stock amp? Use door speaker amp signal? Does the back of the mylink have a sub out that I could/should use?
1) Where is the stock amp? Under the steering wheel and above the driver knees?
2) Can I use a low level line converter, or should I get the Panasonic UZ8 Amp.
3) Can I use any Panasonic UZB 8 Amp? I see some have different model numbers.
4) Will I need to pull the fuse for the ANC amp or since I'm going through the radio, will ANC work at the same time as having my after market sub?
kireol is offline   Reply With Quote
2014 4Cyl Clicking on cold starts kenpoed 2010+ Equinox Maintenance 0 10-31-2016 11:27 AM
Adding a GPS herbf56 Interior Modifications 3 04-19-2015 11:06 PM
Might be adding a new Nox to the family tallbump The Lounge 2 10-07-2012 05:22 AM
Adding OEM options, what's easy to do? charliekeller Audio & Electronics 9 06-07-2012 05:35 PM
In the Market... Equiraq 2010+ Equinox General Forum 21 05-02-2012 07:48 AM
