Odor from AC system
Severum17
Anyone getting an odor from the AC system on initial startup? Sharp kind of smell, cant really describe it.
NOX4ME
Evaporator drains are clogged. Moisture in evaporator will give you a strange odor. Clear the drains then run the AC. It may take a while but it will go away.
Severum17
Great! And the drains are where? Best way to clean them? 2018
NOX4ME
located at the bottom of the evaporator box under the hood. just clear the drain but be careful; don't poke screwdrivers through the bottom you could damage the evaporator.
swisscheese
My AC was stinking badly, I change the cabin air filter and everything was fine. I would check there first.
