Aftermarket Headers due to cracked exhaust manifold
HalftimeB
Hi all,
New here. 2013 equinox LT with 2.4L. Looking to upgrade to headers due to cracked exhaust manifold. Anyone done this? Brand used? I saw these for 2.4L but didn’t know if will fit easy bolt on or not.
ZZP ECOTEC SHORTY HEADER​
ZZP Headers
Any help he appreciated. Thanks
comp
Hmmm you replacing cat. and moding exhaust?? contact them tue. and ask if its a bolt in swap
HalftimeB
No other work being done, just don’t want stock manifold which will most likely crack again.
ALM
I replaced mine a few years ago. Used a standard cast iron manifold I purchased from Rockauto. About $105. Get into contortionist mode as it's a bugger to get to the bolts. Lots of liquid wrench and go easy on backing them out. Aside from that it's a fairly easy task.
Padair
Would anybody know if there are header available for a 2011 Chevy equinox 2.4? I did find out that the Polaris slingshot has the same engine but the the headers are pointing In the wrong direction to the left
